hi, I have question. google eart probable backgound in Microstation? bing maps make to microstation?
MAHMUT BAŞARIR said:. I understand that the microstation is inadequate. both kml does not load. at the same time, google map. static only.
no its not.. I use it all the time its wonderful and microstation Rocks my world and the kmz is great... you must not be using it properly...
I use two screens one for google earth and one for my cad work.. I make sure I have a GCS attached to my cad file and use the google earth pro 32 bit only for V8i... then use the geographic tools bar tool to synchronise google earth, if you want to just check and object location like a pit i use the google map tool and snap to my pit it opens a new map and I can use the walking man to get a ground view and look around.. however If I want a airphoto of the area for a background , then there is a whole diferent process to capture the Goggle earth.and have it georef tiffed. there is a Bentley wiki on this so search google earth image capture.. otherwise use the kmz to view you site superimposed in google earth.. Here where we live and work Bing is not as uptodate as google earth for the life of the project.. and I find Bing only works well with CE as you dont need a MS key in CE...
Lorys
I believe you want to help me. but it is not possible to install googlemaps like bing maps on microstation. google earth captures are extremely inadequate. microstation should be developed. out of age.
Türkiye Devlet DemirYolları Genel Müdürlüğü
Proje Mühendisi
MAHMUT BAŞARIR said:it is not possible to install googlemaps like bing maps on microstation
Did you cast your vote here?
José
YES I did
Answer Verified By: MAHMUT BAŞARIR
in the same way, even though it generates a kmz file, it cannot read the file it generates again. Bentley has been on this issue for the last ten years in which he does a production.
