How can I edit a Cell in MicroStation to have all instances of that Cell in my drawing to be updated dynamically?
Al Ebert said:when I am trying this same procedure in .dwg work flow, I cannot create a new dgn model because only type selectable is "sheet" and "sheet from seed" and the rest is grayed out
Please reveal all relevant information when you post a question!
DWG files don't support multiple models. When you use MicroStation in DWG mode, it applies that restriction imposed by the DWG file format.
Al Ebert said:Note sure if there is a [MicroStation] configuration setting for this?
You'll have to ask AutoDesk about providing multiple models in a DWG file.
Al Ebert said:I use both AutoCAD and MicroStation and it is much simpler to work and edit blocks in AutoCAD
A DGN model is a DGN cell. A DGN cell is a DGN model. A DGN file contains one or more models or cells (they can coexist in the same DGN file).
Because DWG lacks the facility for multiple models, you must modify Ron's proposed workflow Step 2. Instead of creating a new model in the active DGN file, you must use another DGN file as the cell library.
Thanks Jon, I understand.
I though that if you have a shared ell used all over your drg if you edit one manually inplace like text thenthey all update automatically main reason I dislike shared cells..
I think to do what you want
drop all the shared cells to normal cells.
copy one and drop to geometry ie nolonger a cell then edit how you want it to look, then turn it into a cell but first movie it 0,0,0 and then attach your cell library and create/ turn it into a cell old school way now if you name it the same as the other cells you can easily use the replace cell option in the cells pallete...and you'll have a cell in library for future use...
Lorys
Lorys said:drop all the shared cells to normal cells
The OP has revealed that he's working in DWG mode. A DWG file accepts only shared cells (AutoCAD blocks): it doesn't understand MicroStation's concept of normal cells.
oops missed that detail sorry folks...
