in Microstation V8i I have successfully exported to kmz files - and get the expected results - for viewing in Google Earth.
However, I have recently upgraded to to Connect Edition and now get placemarks (push pin and style no.) appearing in Google Earth. See image.
I do not want the placemarks. Is there a way to disable these, I didn't get them when using v8i.
Thanks for any assistance you may give.
Sorry for the delay in response to your issue. Which versions of MicroStation V8i and CONNECT are being compared with this workflow? What version of Google Earth Pro is being used? Maybe if you could supply an example design file along with your workflow we can try to replicate what you are seeing.
I'm having the same problem. Its frustrating. Have not found a solution yet.
Just mentioning that you have the same problem does not help with an investigation into your issue. If you could please follow the MicroStation Forum best practices this would advise firstly to provide the software and version being used. It would also be helpful to outline your specific issue as this may differ to the original post. Example files and screen captures also assist with understand what your issue is regarding. It may in the end be better to post your issue as a new post in the forum and reference this issue if it is related.
It might be one of the levels under levels can be turned off to eliminate those. They are attributes from some graphic feature. There may also be settings in Google Earth, don't know.
Update:
Microstation version is Connect Update 13 v10.13.00.48
Google earth Pro version 7.1.5.1557
These versions are locked by my company IT, I cannot upgrade to a later version until they say so.
Unfortunately, trying to turn off particular levels in Google Earth also turns off the line work.
