i have some DWG files when i am converting them from DWG to DGN using microstation batch convert some drawings, tables are missing please can someone give me solution for this i have uploaded pictures of bothplease have a look and suggest me a solution to this please
King Khan said: i have uploaded a DWG and a
Can't see any files! Use the Insert|Insert image/video/file button to add a file to your post.
no sorry i have upload the screenshot of AutoCAD drawing and converted microstation drawing can you cant solve this by screenshots ? As you can see in screenshots right side table is missing when converted to microstation
King Khan said: As you can see in screenshots right side table is missing
Screenshots describes your problem very well, but the will not give any hind "Why?"
Mit freundlichen Grüßen / Best regards Volker Hüfner
| AB_DATE Engineering Software | ab-date.de |
King Khan said: you cant solve this by screenshots ?
Correct! All we can see is what you can see. You need to attach the DWG file to enable someone to analyse the table.
King khan,
your table data in model or paper? if model it will not come first transfer the data to paper then convert.
