hatch scale changing in different versions of MicroStation
Why would a simple hatch show up one way in CONNECT and another in v8i? In CONNECT the scale changes. The picture below shows the difference. The first picture is CONNECT with the tight hatch pattern. The second is the loose pattern which is what the engineer prefers.  The hatching is in a referenced file. After I first posted this question I went in and turned off the Annotation Scale lock for the referenced file. Now the hatch appears the same as it does in the v8i session. I'm going to go see how turning off the AS lock affects the text and other linestyles scales.
I am using MicroStation CONNECT Update 12 - Version 10.12.00.40
Thank you
