I know a simular questions has been asked but I would like to know is there are any updates or guides on how to get expressions to work in reports.
I use expression for some attributes attached to cells. There is a origin and a rotation (I know I can get this from the cell at report time but this how the customer wants it!).
The ItemType has the following attributes:
Origin is defined by this.getElement().Origin
Rotation as: this.getElement().RotationZ*180/System.Math.PI
This works fine when looking att the attributes (apart from my previous question regarding UOR2MU) but in the report these fields are empty or null.
Is this supposed to work?
A file is attached with some items and a report.
/Krister
3681.Test.dgn
Hi Krister,
Thank you for your feedback.We have already addressed Unit conversion issue in Update 14.Also, expression will get executed for reports also and will able to see result in Update 14.
