Hi all
I'm working in MicroStation CONNECT Edition U12 (actually ORD 2019 Release 2) and I'm having some issues with creating custom 3D linestyles.
There are two issues:
In the screenshot below, the elements used to create the linestyle are shown (guardrail rail, flared ends, spacer block, and post) and to the right is how the linestyle displays when used. The guardrail posts show as wireframe instead of a solid... The materials aren't as big an issue as the posts. Anyone know how to fix this?
The guardrail posts are Smart Solids, the spacer block is a Slab, the rails are Extrusion Surfaces, and the flared ends are Smart Surfaces.
Kind Regards
Hi Warren,
Warren McLachlan said:The guardrail posts are Smart Solids, the spacer block is a Slab, the rails are Extrusion Surfaces, and the flared ends are Smart Surfaces.
Please follow this post that possibly could be the same issue as the one that you have.
Regards and hope this helps.
José
