Would you be able to clarify exactly what this issue is relating to with this Side Bar Menu?
Is this a tool supplied or produced by a 3rd party?
How is this related to the operation of this function menu or digitizer tablet?
Maybe you could include example files, screen captures, error messages etc to assist.
K Mahendran said:The SBM tool not working
Repeating that something is not working doesn't help. It's like visiting the doctor and saying: It hurts when I do this! To which the answer is; Don't do that!
Please answer Andrew's questions to help us provide a diagnosis.
Andrew Bell said:clarify exactly what this issue is
Andrew Bell said:Is this a tool supplied or produced by a 3rd party?
According to Ivo Blaauw in this thread, it's simple enough to read a SBM file and add its commands manually to MicroStation/PowerDraft's function keys. Note also that SBMs are ancient technology that have been superseded many years ago by MicroStation/PowerDraft's customisable user interface.
The following tools was produced for MicroStation V8 XM Edition to convert the Side Bar Menu files to XML to import into a DGNLib for use in your workspaces. This is so old a concept and tool that we never produced this for any further versions of MicroStation.
https://communities.bentley.com/products/microstation/m/bentley_library_utilities/138926
The side bar menu tool would no longer be supported so we would suggest moving to current technologies with storing and configuring your menus in DGNLib files within a MicroStation workspace configuration.
It would also be suggested that you should be upgrading to a currently supported version of MicroStation or PowerDraft. The older V8i versions have discontinued support after January 1st 2020. You should either be upgrading to V8i SELECTseries 10 or CONNECT Edition.
