Check out a Master Class on 3D Basics of MicroStation CONNECT Edition by Sam Hendrick in his engaging style. This is a great set of tutorials for beginners and a refresher for experts.
https://communities.bentley.com/products/microstation/b/microstation_blog/posts/microstation-connect-edition-3d-basics
Connect
Hi
I have been using Microsatation 3D modelling for over 20 years and reasonably good at that. I have been interested for some time generating 2d drawings form 3D model but failed several times, trying to fit in the learning process into too small time slots.
Can you please advise the best place to start self teaching the process?
Although the Blog referenced by Sunand Sandurkar is from the end of last year this should be helpful in showing you a number of learning modules you might like to have a look through the Bentley Learn Server for other courses relating to 3D modelling.
https://learn.bentley.com/app/Public/BrowseLearningPaths?productlineId=326&CustomLP=False#
Thanks Andrew,
I tried a course similar but git stuck very early. Tried again and got stuck again on "Select Your Data Set..." page
There is no data set:
Can you please advise further?
Thank you Sunand
Thank you for your message. I tried to follow the tutorial below before.
It starts by stating to use a file "Roadways Plans,dgn" adding "unfortunately, it does not come with shipped version". Does not appear to offer where to get the file and continue with the tutorial.
Where can I get this missing file?
PS Perhaps I should start with Model Space/Paper Space Tutorials. I have managed using Dgn Sheet Files for various scale and paper sizes and attached ref files to generate drawings (see attached samples). I would have prefer to generate 2D from 3D model closer to my work process but it may not be possible and I might have to learn Paper/Mode; space. Your guidance on this will also be most appreciated.
172--61 2 Arch Quality External 1 to1.dgn 157_P00 RevE Gr Fl 1to50@A3.dgn
