This happens every so often and I am wondering if this has ever been fixed. When I try to trim to intersection sometimes I get a corner (what I want) but then sometimes the arc goes all of the way around. Like I said this doesn't happen all of the time but it DOES happen. Has an answer for this been given?
Thank you
Always a good idea and provide details of your issue according to the MicroStation Forum best practices. Which software and version?
I may also be helpful if you could provide an example design file to try to replicate what you are seeing.
Dbl J D said:This happens every so often and I am wondering if this has ever been fixed
As you have mentioned in this statement that it has happened to you before, have you previously reported this? Was a Service Request or Defect raised for it?
As far a I can remember it's always done this on occasion, v8i and Connect. Must be some logic, but I've never figured it out. File a service request, Bentley will get a little kid to take you for a long walk in circles, leave you lost in the woods and never come back.
Thanks for the replies. I haven't filed a service request, I feel it wouldn't get enough attention to get my hopes up, anyway I'm still using v8i and I don't see much, if any, support for anything but connect. I was just checking to see if anything had been done for this. Bob Rayner, I like "it's always done this on occasion"....Funny!! :-D
Thanks again
Without examples to try to replicate what you are explaining as an issue for you it is difficult to know whether a Defect or Service Request has previously been raised or if it may be related to your files or workflow. It would also be helpful to know the exact versions of MicroStation you are replicating this issue within. eg. 08.11.XX.XX or 10.00.XX.XX
Andrew Bell, I'm sorry I always forget to add the version. I always am able to get what I need to in this situation i just extend the arc past the line and trim everything to get the "corner" I am looking for.
v8i, ss4, ver. 08.11.08.832
