Several posts about text vs text nodes but I cant find any decent explanation of when and WHY to use either/or. Why is there two options, etc.
There was a posting about converting text to text node but nothing to explain why you'd need or want to do that.
Obviously I know how to place text/notes, etc. on drawings . . . just wondering where either text or text "node" would be most appropriate.
From the Help file, it would seem to be more appropriate to use text nodes IF you are placing them as a placeholder for text to be added later. The two points below are from the Help.
1. Used to place empty text nodes in a design to be filled with text later using the Place Text tool or to be linked with a database row using the Attach Displayable Attributes tool.
2. During the design process it can be efficient to insert placeholders for text to be added later.
There are two types of placeholders:
Hi Dan,
Dan Eckstein said:but I cant find any decent explanation of when and WHY to use either/or.
my recommendation is "When not required explicit element type, do not care." ;-) Simply place text and edit text, MicroStation will do the rest automatically.
Dan Eckstein said:Why is there two options, etc.
It's because of history of design file format evolution ... in times when every bit was counted.
Dan Eckstein said:why you'd need or want to do that.
Usually there is no reason to convert one type to the second one. Such requirement can appear, but it's often context specific.
With regards,
Jan
Dan Eckstein said: Text vs Text Nodes: I cant find any decent explanation of when to use either
A text element is just that, and no more.
A text node is one of at least two ways of grouping several elements. It's handy when you want several chunks of text to remain spatially related. A cell with text components performs a similar role. In the old days, it was hard work to edit text inside a cell, but these days it's easy.
We often create a text node inadvertently. A single text element has a single style. If you write some text in MicroStation's text editor and change the style of one word, then you automatically create several text nodes. For example,
text
Usually, you aim to create simple text elements. Circumstance may lead you to create a text node element. As Mark comments, you might want a text node as a multi-line placeholder for later editing.
Following on from Jan and Jon, I prefer not to use text nodes as some of the newer most useful tools wont work on text if they are text nodes example my favourite tool copy increment text will not work with text nodes.. as for using enter data fields I personally don't use them any more as there are better tools today like items and tags which can have preset fonts , txt size , text and levels and be turned on / off .. but if you already have them then keep using .. horses for courses after all...
Lorys
