Often I need to measure the projecting distance of a cylinder (pipe) through a sphere (or cone).Or to make this question easier, how do I measure where a line intersects the surface of a sphere in a 3D model. The true length would best be seen in the front elevation view.
To this point I have been using the subtract solid command to make it easier to snap to the surface of the intersection point but I am sure, there must be an easier way to measure this distance or place a dimension (in order to get a distance).
Thanks for your help.
Measure distance>between points will give both the true distance and the projected distance. You could also use Dimension linear size with alignment set to true.
