How to do the zoom in detai l (enlarge on portion of the area to certain scale)?
For example, I have a gas line in the 1"=200' exhibit, I want to enlarge only (zoom in) that gas line in a scale of 1"=40'. How do I do it ?
Not sure what the work flow is here, but for this I would reference the gas line exhibit, then scale by 200÷40.
what version msnt?
are you using sheet models?
Are you using annotation scale in your model settings?
do you just want a view in the model to be that scale or a finished drawing detail either in model or sheet?
Do you know how to make a saved view by 2 points, then you can ref that save view just like a view port in acad on the sheet or in the model itself..
we need a lot more info to help you exactly.
Lorys
I attach the base files as a reference. I can change the scale of that reference to something else (in your case 1" = 40') and clip the reference to show just the area I want to see. Then I can move that "zoomed in" reference attachment anywhere on the sheet I like.
MaryB
Hi Minhdang, I was looking for the same like you (I suppose :-)). I found something like this: I select the element and fit the view to select element and change the annotation scale in the same time. I created some icons for it and used different combinations for the settings: set displayset on;selview 1;displayset set selection;fit all;point ab;displayset clear;update view extended;model set annotationscale 150
