Hi all,
Seeing that Item Types is the new way to add attributes to elements, is there any tool (or anything planned) to filter or search for elements based on an Item Type and/or it's property?
Maybe time for a revamped Select by Attributes tool?
Mark
Hi Mark,
Mark Shamoun said:is there any tool (or anything planned) to filter or search for elements based on an Item Type and/or it's property?
Sure, it is ... from (I guess) very first CE version ;-)
It's possible to search for elements directly in Explorer.
The tool is sometimes a bit weird (and too complex), also not all scenarios are supported (e.g. to search for nested elements recursively), but basic search if very simple:
It's possible to create complex search criteria (especially when not "Add Criteria", but Advanced Search dialog is used), but ItemTypes are displayed in basic list (custom "Test ItemType" displayed in the picture), so it's enough to choose the proper one and to specify the condition.
When the elements are searched, the results are displayed in Explorer in Search node and the elements are added to Selection Set.
You can use the search as a definition for MicroStation Report (and Tables) mentioned by Jon, or using Details you can search / sort / filter / export to Excel /... records accordingly your needs.
Mark Shamoun said:Maybe time for a revamped Select by Attributes tool?
Searching directly from Explorer can replace Select by Attributes in many situations.
With regards,
Jan
