In Microstation Select Series 4 (and using the Legacy tools in Cu13) we where able to Cut / split multiple Solids at once:
In MicroStation Connect however I cant Cut / split more than one Solids at a time.... Is this reduction of functionality a bug?
Regards Louis
I can't help you with your question, but I'd like to commend those videos you have provided as evidence!
Hi Louis,
it has been discussed several times already, see e.g. this discussion.
I vaguely remember Service Ticket and technical details were provided in relation to this issue, but I was not able to find this discussion.
I found a workaround (see linked discussion), but it requires extra step and probably cannot be used always.
With regards,
Jan
Thank you Jon and Jan,
If it's discussed before, than I hope this functionality would be available in the next version....
Jon, feel free to comment.
