Is there any way to utilize the underlined letters in a command menu as a shortcut
For example:
[S], [1] activates Place Active Cell:
Menu items are:
Active Cell
Active Angle
X Scale
Y Scale
etc.
C, A, X, and Y are underlined. Is there a way to activate those items with the letter that is underlined?
Thanks in advance!
If the Tool Settings dialog is in Focus (F10 or click on the Tool Settings dialog), then you can press and hold the 'ALT' key followed the 'Underscored' letter to activate.
See also https://communities.bentley.com/products/microstation/w/microstation__wiki/15939/auto-focus-tool-settings
Answer Verified By: Rich Baird
This works! Thanks Carl.
