Dear Bentley Communities,
I am using MicroStation V8i series3, for Saudi Aramco projects with Auto-SACS (6.1) tools & I am facing the problem when I am editing the tile block info with Auto-SACS tools as mention below.
1) When I am changing title block information, drawing title in the Auto-SACS data entry and run process.
2) After running the process Auto-SACS default colors setting is not appearing, it's changing to another color, for example, red color, it should not be.
3) Auto-SACS default colors setting for example 2, 7, 61, & 63.
I would like to know how can I resolve this to default Auto-SACS color setting, Is this MicroStation error or any kind of bug, etc.
Regards,Mansoor
AutoSACS is a custom application from Aramco which runs on top of MicroStation. Any issues with AutoSACS must be reported to Aramco.
I guess it could be a color table issue. Check the attached color table in the original drawing. Key-in “CT=?” can be used to check the attached color table.After running the AutoSACS tools, check if the color table has changed.
The color table is sacs table
Mohamed mansoor said:The color table is sacs table
Leonard Jones said:After running the AutoSACS tools, check if the color table has changed
Has the colour table changed?
Mohamed mansoor said: Is this MicroStation error or any kind of bug, etc.
MicroStation colour tables have been tried and tested for several decades. The likely culprit is the AutoSACS tool. We know nothing about it.
To test this...
Are the colours correct?
If the colours are correct, then repeat the above, with two changes...
Good day Mohammed,
Have you looked at settings for symbology level override?Try CTRL+B on your keyboard and see what happens if you check/uncheck "Level Overrides".If that changes the color back to it's original; then you need to do is check the levels in the Level Manager.
Ivo Blaauw= = = = = = = = = = = = =Look what the CAD dragged in...
