Text in Cells Disappear when Converting to AutoCAD
In converting a Microstation file to AutoCAD, I'm having issues with the text in cells ("blocks").
In the conversion, the text "blocks" from Microstation are not being maintained. In other words, the text from within "blocks" disappear once the drawing is converted and opened in AutoCAD.
Moreover, I saw the following solution posted in another similar thread: "The text is most likely part of an Enter Data Field (EDF). EDF's are not supported in AutoCAD. Therefore, they (EDFs in Cells) are converted to Attributes (AKA Tags in MicroStation) that are associated to the converted Block in the Save as DWG process."
Is there a work around to this?
Any help would be appreciated. Please see attached
4606.Microstation File.dgn
