Our firm has been trying to setup Sheet Indexing and we are experiencing some issues. When we open the Explorer dialog and go to the Sheet Index Tab the necessary icons are not available.
First image shows our Sheet Index tab. Right-clicking on the 1 icon that is there brings up Refresh (greyed out with a check mark) and Show All. Selecting Show All does nothing. The second shot shows what icons should be available.
A colleague discovered that the Personl.explorer-settings,xml, which is pointed to by a config variable has different values than the one supplied with the training materials. He edited the .xml file and was able to get the icons to appear, however the icons are all greyed out.
He did have post on the ORD forums, but this is a Microstation issue. https://communities.bentley.com/products/road___site_design/f/geopak-inroads-mx-openroads-forum/190394/sheet-index-toolbar-missing-icons
While it is good that he was able to get the icons to appear WE SHOULD NOT NEED TO MODIFY .XML FILES!!!!!
Also, going into the Explorer Settings dialog through the backstage shows only 1 option, to make the Sheet Index Tab visible in Explorer.
This post https://communities.bentley.com/products/betas/openroadsdesignereap/f/openroads-designer-early-access-forum/130787/sheet-index states that you only get the icon when you enable the Edit Sheet Index option. Where do you go to enable the Edit Sheet Index option.
I do have a file where I created a sheet model and I had Add to "Sheet Index" checked on. When I look at the properties of the Sheet Model under the "Sheet" tab "Sheet Index" value shows Not in Sheet Index (greyed out). Also right-clicking on the sheet model in the Models dialog box I see to option relating to Sheet Indexing. 1 is Remove from Sheet Index 2 is Navigate to Sheet Index. Both a greyed out.
I did look at this through an out-of-the-box install of Microstation using the Trianing Material workspace/Workset. Both the Training & my customized configurations for the variable MS_EXPLORER_SETTINGS are pointing to the same .xml file (this would be the one a colleague modified on his PC), but the Sheet Indexing icons appear in the Training workspace.
So is this controlled by a .dgnlib somewhere? I am at a loss trying to track this problem down.
Microstation CONNECT Edition Update 13 - Version 10.13.01.01
For what it is worth I am working with the PennDOT configuration as well. It did not seem to have anything to do with their configuration. At least on my end.
Every discipline appears to use the same .dgnws file for the project. Has anyone ran across an issue with this? There may be times when each are working on sheet development around the same time.
colliersengineering.com
Do you have separate WorkSets for each project?
Yes, each project has its own workset.
Without knowing more how you have your Workspaces configured, It seems to me that any discipline that opens a file within a project WorkSet will be using the same .dgnws file. The WorkSet name is linked to only one .dgnws file. I am not sure if there is a way for multiple .dgnws files under each WorkSet or not. I would contact Bentley about that.
