Control visibility via color, not just level?
Good Afternoon -
In a particular referenced view, is there any way to control an element's visibility by color rather than level? If I have say 5 identical elements (all on the same level) in a drawing, and I turn that level off, all 5 elements are no longer visible. After changing the color of one of the elements, is it possible to turn the visibility of that element off while leaving the other 4 visible, even though they are all on the same level>
