I have multiple lines , how can I change direction of all of them at once? Right now I'm using utilities-key-in-change direction, it's a hectic task when there are many lines. Thanks!!
Perhaps I'm missing something here, but I thought this could be done in V8 any version?
This will make all directions of the selection set changed.
Ivo Blaauw= = = = = = = = = = = = =Look what the CAD dragged in...
Yet another example of what holding an extra key (CTRL, ALT or SHIFT) can do in Microstation. Thanks Ivo!
(just try holding CTRL while selecting handles and then move one or look what holding SHIFT does when selecting elements through a "rectangle")
You will have to open it in Microstation v8 2004 Edition before the tool was "improved" with these arrows.
In CONNECT Edition no longer works with selection set.
Disableing features so people like Jan and John have to write a workaround for us. Why? Bentley, why?
