Finding Master Unit data in VBA without label
I am having some trouble with some VBA code to Insert Cells. The VBA code is not the problem, i have tracked the issue down to the UoRUnits as seen in this thread.
https://communities.bentley.com/products/microstation/f/microstation-forum/187632/text-size-multiplying-automatically---why?ReplySortBy=CreatedDate&ReplySortOrder=Ascending
My problem now is similar but not exactly the same. I am trying to adjust my code to factor in the units of the Default Model. All of these files are exported from AutoCAD to DGN.
The units of the File are in Metres, but there is no label.
When i try to find the "Metres" values in VBA it shows nothing.
So my question is, how can i find the "Meters" value if there is no label?
Using V8i SS10
Thanks.
