I just updated to powerdraft connect version 13 from version 12. My "edit text" command is only allowing me to edit one text field then I have to enter the "edit text" command again to edit another text field. How do I change this setting so that when I am in "edit text" mode, I can continuously edit different text fields without having to type the "edit text" command every time? this has never been an issue before.
Jake
Jake Tomlinson said:My "edit text" command is only allowing me to edit one text field then I have to enter the "edit text" command again to edit another text field
It's a bug! Read this thread to see a similar question and Bentley Systems' answer.
Hi Jake Tomlinson,
Similar to Jon's recommendation, I suspect if you update to MicroStation CONNECT Edition (Update 13.1) it will correct issues like this related to Defect 1050395. Please let us know if you are still seeing this issue after the update.HTH,Bob
