We have noticed a discrepancy lately when measuring surface area from a reference file inside a model. The area in the reference file (when opened directly) measures differently than when we measure it as a reference in a model.
We have verified that the design files have the same units, decimal position, etc. The only significant difference is that the model scale is at 1:100. The difference between the measurement in the reference file and the model is a matter of 1.2295m2. To complicate matters a bit more, when I copy the shape from the reference into the model , its area is the same as the original reference file, and not the measurement as when it is in the model.
Does anyone have any suggestions? Both files are 2D, Connect v13
Bugs, Connect is loaded. Best file a Service Ticket (good luck).
Corinne said:Both files are 2D
Can you post your two files or, preferably, a slimmed-down version of them?
Is there a place to upload here (my first time in the forum)
Is there a place to post here? Its my first time using the forum .
Corinne said:Is there a place to upload?
You can attach a file to your post using the Insert|Insert image/video/file button.
