In MicroStation V8i, we use the task in MainClassic.dgnlib. Because our users want to continue using the same key-in shortcuts in MicroStation CONNECT, we copied this dgnlib to the CONNECT-environment.In MicroStation CONNECT Update 13, we select the workflow Task Navigation and the task Main Classic. But then, in the ribbon group Manipulate, the first five tools are not correct: instead of Copy the tool Copy to Clipboard is displayed instead of Move, Scale,Rotate and Mirror the raster tools Raster Move, Raster Scale, Raster Rotate en Raster Mirror are displayedWe opened MainClassic.dgnlib (CONNECT-version) and tried to correct this via Customize. But when we drag a separate tool (or the complete Manipulate tool box) from the application tools into the task, the application-tool reference is immediately changed into the raster version of the tool.How can this be solved?
can you post the mainclassic.dgnlib please
Is this what you are looking for but in CONNECT?
No, this is what we want, but then with the correct Manipulate tools.
OK. What does it look like in V8i. Do you have the dgnlib that goes with it. feel free to email me if you want to discuss this offline..
PM me.
Ian
