How to I adjust the display resolution of my model/interface when the camera mode is off.
When I click normal camera for example the display is high resolution and I can dynamically move the view with a clear display, however I click camera off it switches to an low res version with lots of messy edges.
I assume this is an easy setting to adjust somewhere?
Thanks.
James Taylor said:How do I adjust the display resolution of my model/interface when the camera mode is off?
If your question is about visualisation, then there is a Visualization Forum that may be a better place to post.
