I am running MS Connect V12, my drawing is in US Survey Feet and I want to reference in a .dwg file that also is in US Survey Feet. When the referenced .dwg comes into my drawing MS assigns Feet as the unit. What settings do I need to configure so MS will default to the units in the .dwg?
Sorry for the delay in response to your issue. Would you be able to supply an example master / reference file to test your issue? If not, it may be helpful if you could show some screen captures for what you are explaining.
