I'm trying to figure out how the subscript and superscript work, but can't find any documentation in the help. Does it work on just certain fonts? Thanks.
Eric,
Make sure you don't have "Apply changes to all text" set and avoid Text Styles with Background Border or Under/Overline.
Roy
Dear sir,
I have try to setting Superscript or Subscript is True. It's can work. My question is "Can we set both of Superscript and Subscript as True at the same time?
Gon
Are you talking about super & sub script settings in the text style or in the word processor?
For styles, it can only be set to one of the script settings.
In the word processor you can use both in the same text element as long as the "Apply changes to all text" option checkbox is turned off.
Talking to Bentley the only way to control the size of the text in the script is to create a specific style to handle each type. Note, the superscript option has a problem where as you increase the size of the superscript text the base of the text starts to getter higher and farther away from the normal text. A CR has been filed for this bug.
