Following up on this blog at https://communities.bentley.com/products/microstation/b/microstation_blog/posts/steel-now-available-for-microstation-connect-users it refers to a location of the files to be copied to |MicroStation\mdlapps\
I don't have this folder in our server location which CE points to. The closest I have is "\Organization\Mdlapps"! Do I copy all the steel files to this location?
Bentley - Could you advise on this.
stuartw said:I didn't create this folder. It is a copy
If you copy something, you have created a new something. It is an action you performed using Windows tools. MicroStation doesn't know about it.
I have downloaded the .zip file. When I copied into the folder and loaded the application, I get "File steel contains an old version of the application steel". Looking at the dates on the .dll and .ma file, the dates are vintage 2010....
WTF Bentley? I get that same error.
yep..same error so its not the new version... I just tested in V8iss4 and it runs steel 99 so its same or maybe updated v8i version to have the newer sections available .. but ok can use in V8iss4... but its not the ported connect edition yet...
Lorys
It is byte to byte the same version as v8i. April fools but little too early.
