Hi
Seems I can't have key-ins stacked after each other when they are in a key-in link. I want a link to this one:
level set active default;level set display off file:all all;point ab;level set display on file:all K-???-35???
I also tried to place that in a .txt file and use the "@C:/..." keyin. Works great from the keyin dialog, but not when put in a link. What I'm I doing wrong here?
Robert
Please confirm which Product and Version your using.
Your keyin within added to a Link works for me works in MicroStation V8i SELECTseries 10, but not in CONNECT Edition Update 13.
One workaround In CONNECT Edition is to record a Macro using your keyin, then the Keyin to run Macro 'MACRO PLAY macroname' can replace your Link keyin,
Carl Myhill
Technical Support Engineer
Bentley Systems
Running Openbuildings designer update 6 connect edition (based on MS U13). So guess that's why.
Ok. Don't really like workarounds, but I guess I'll have to go with that one.
Hi Carl,
thanks for your test. Has been defect number created for this bug?
With regards,
Jan
Hi Jan,
I am awaiting confirmation, but will update thread with Defect.
Carl
Defect 1075695 has been filed and resolved in Update 14. Thanks for reporting
