I have an old license ( MS (XM) + TF+ BA 8.9.4.46)
now I had to replace the BA to a new machine with win 10
I 've become a new node locked license from Bentley for MS & BA,
but installing BA on top of MS installs first TriForma, without TF, BA can't work
now the program asks for a license file for TF too, but Bentley says they can't make such a file,( the TF is a part of the select program)
so now the lic is worthless because the TF isn't licensed anymore
someone else whit such a problem - what was the solution.
Regards Rik
btw: after installing the program, the lic works for a month,but the word processor fails to work (see https://communities.bentley.com/products/microstation/microstation_printing/f/printing-and-plotting-forum/191614/word-processor
someone a bug fix for this?
Moved to Licensing and Activation Forum
Warm Regards,
Subhamoy Kundu
MicroStation V8 XM Edition, along with Bentley Architecture (XM) and Triforma, are not supported for use on Windows 10 systems. You will need to upgrade to a current supported version of MicroStation CONNECT Edition, or at the very least the V8i SS10 version.
