Hey everyone!I have a text string. This string must be entered in the cell (or just between two points).Have any ways to auto-scale this line? (or auto-compress text spacing)Thanks a lot
Select the text, and grab/drag one of the corner handles?
Wthout using the mouse. I write/edit the text in the editor, and it selects the scale automatically
Hello Denis,
When in the Place Text command, select from the Place Text Attributes 'Fitted' (middle icon, with crossed arrows) This will place the text scaled between 2 points. Note that the placed text will be scaled proportionally (height and width) If you want to keep the text the same height, but scaling the width you need to go back to the scaling tool and use the 3 points Method
René R. van den BrinkTechnical SupportBentley Systems Incorporated
Hi Denis,
I would recommend a solution with a little programming. A program that measures the bounding rectangle, and if it violates the boundaries, scales the text until it fits.
Mit freundlichen Grüßen / Best regards Volker Hüfner
| AB_DATE Engineering Software | ab-date.de |
Hi Volker,Is it possible to do this with a set of key-in or VBA? What way is more easy?
