I have created a couple of Text Favourites in our DGNLIb, using a text style that we have for use with drawing sheets. Essentially text should be 3.5mm high x 2.5mm wide.
When I want to add to a drawing the text come out 100 times smaller!
And is unreadable!
I have tried changing the text height in the Text Editor but this makes no difference.
Is this a bug or am I doing something wrong?
Turn annotation scale lock off or on will affect size.
Bob Rayner said:Turn annotation scale lock off or on will affect size.
Turning on and off doesn't change the size I'm afraid.
Stuart
In either file DGNLIB or the active DGN file,do you have annotation scale active?
Ian
Have you checked the design file settings ie Units of resolution (UOI) ie do they vary
also check both files have same master units.
Lorys
