I have created a couple of Text Favourites in our DGNLIb, using a text style that we have for use with drawing sheets. Essentially text should be 3.5mm high x 2.5mm wide.
When I want to add to a drawing the text come out 100 times smaller!
And is unreadable!
I have tried changing the text height in the Text Editor but this makes no difference.
Is this a bug or am I doing something wrong?
Could you please share the .dgnlib ?
Abhay
Ian Lapper said:Have you checked the design file settings ie Units of resolution (UOI) ie do they vary
Ian. Having just checked my DGNLIB has a resolution of 10000 per Distance Meter, but my drawing sheet has a resolution of 1000 per Distance Millimetre. As far as I know this has never been a problem with any files the we use with this DGNLIB. In fact all files look at this DGNLIB!
Lorys said:also check both files have same master units.
They have the same master units of Millimetres.
Attached as requested3326.ws-gui.dgnlib
That's the issue, just went thru this with some of my standards files. Some items in Microstation will scale by master units, others by units of resolution.
