Maximum number of Tags in Tag set
Is it possible that the maximum number of Tags in a Tag Set is 12 ? I do not seem to be able to have more than 12. I tried to add some tags >12, the new tags are there but others are lost. MicroStation V8i ans Connect Edition update 13. same problem. thanks, Nico
  • Thank you Jan,
    there is clearly some strange behavior and it often jumps back to 12. As mentioned, I think it may come by jumping from V8i to CE back and forth. I created a documented ticket for this. Problem is that I can not reproduce. Just have screenshots. Today stable, we will see tomorrow. thanks again.
    Best regards,
    Nico
  • I'm swapping between versions for same files and not getting that kind of behavior, but no Pwise.. so it is probably how pwise is being set... maybe it needs to be different for CE...
    Support moved to India your kidding, your still in Brussels ( your profile says so, don't panic no big brother spying here) .. you would think Europe has more users than Australia.... IMHO things just seem to be getting worse for us users every year .... eg no home license for CE.  No datum patches to pre connect versions for any new GCS datums  etc... I don't like being forced into using CE but its getting more and more that you have to.. I know we have to move on, v8i is now too old...  its like that comfortable pair of slippers that are  worn out but they are so comfortable you just don't  want to throw them out and get new ones (sigh) .....
    Lorys
    click link to PM me
  • Lorys,
    Ian Lapper, Chairman of the UK Bentley User Group, posted a "vote" topic for getting back the home use availability.
    https://communities.bentley.com/products/microstation/i/data_interoperability/ce---home-use-license-not-available-in-ce
    vote in the little grey box top left of the item.
    Best regards,
    Nico
  • Were going off topic here but....
    yes its over  18 months old and still no progress and I voted for it  way back... very disappointing.. this is one of the things that used to set mstn apart from all other  software and I learned more from trying at home in my own time with home license that I ever could at work when  its all pressure and billable hours...
    I even help others through the forum and try or test via my  home license  for v8i... not so with  CE...
    Lorys
    click link to PM me
