Has the option to have task navigation set to dialog been removed in connect version 10.13.00.48?I have had this set up in previous connect versions but since updating i cannot seem to get it back.
Open Configuration variables dialog and add the following variable and set it to 1.
MS_TASKNAVIGATION_CONFIGURATION = 1
Check Wiki How to display the V8i style Tasks dialog in MicroStation CONNECT Edition
If you upgrade to the latest update/version, you can set Select Task to V8i Task Theme
Set Workflow to Task Navigation
I attempted to follow the process in the attached link however i could not get this to work. in settings the task navigation option was not visible
However i have set my task navigation to v8i task theme
Hi Euan,
Euan Rankin said:I attempted to follow the process in the attached link however i could not get this to work.
it's because you use Update 13, where V8i theme was introduced.
The use of configuration variable is available in older Updates, but as far as I know, does not work in U13 (it makes sense, as it would duplicate the functionality).
Jan
As Jan and Leonard mentioned, if you're using MicroStation CONNECT Edition (Update 13) then you would have the V8i Task Theme rather than the option of using the MS_TASKNAVIGATION_CONFIGURATION variable to set this. The following Wiki article explains this but you may not require this as you appear to have located the V8i Tasks Theme ok.
https://communities.bentley.com/products/microstation/w/microstation__wiki/43148/enable-v8i-task-theme-in-microstation-connect-edition
