Hi everybody,
could you help me to find a way how to export 3D model made in Microstation V8i to Archicad?
Hi
try IFC... I think
Also, I would use Mstn CE. V8i is very old at this point.
Hi Dominic,
can I export Mstn model as IFC? I have Mstn CE version 10.00.00.25 and there is no option to export to IFC.
Thank you,
Jiri
MS Connect cannot export IFC. You would need Open Building Designer for that. MS is just a CAD data format, so there are no benefits for IFC. Therefore, you are probably best exporting to DWG
Ian
I found this as well:
https://helpcenter.graphisoft.com/knowledgebase/25765/
It looks like Archicad can import DGNs - scroll down the page to "Other formats (CAD Formats)"
Timothy Hickman
Main: 877 627 3772|
Hi Ian, dwg works pretty well. They get all my 3d solids to Archicad. Only problem are 3D lines (centre lines of beams) which are not imported correctly from dwg to Archicad.
