I have 700 line styles within micro station that originate from an .RSC File. All of the line styles contain a keyword which needs to change to another word. Is there any quick way to do this all at once as manually changing the names one by one would take too long.
It is possible to use a Hex-Editor, but is it wise? You have no immediate control over your results, and some damage may not be discovered until much later.
Mit freundlichen Grüßen / Best regards Volker Hüfner
| AB_DATE Engineering Software | ab-date.de |
That is why I said try with copy and iit seemed a logical approach, but I did say it might be a complied format so it may corrupt it...
oh well looks your stuck with create a new rsc file and import and rename one linestyle at a time ... 700 times at 90 second= 17.5 hours work well looks like grunt work for a junior or low paid employee.. maybe student show them the steps and away they go for the next two to 3 days...
Another reason I say make a new linestyle is your old drawings will still need the old line styles to work
Maybe this isnt worth it labour wise and go back to your masters and explain it will take at least 20 hours labour ( allowing for fatigue and boredom slowing you down) and is it worth it ...
Lorys
Im my opinion, a human approach in such a solution is very ineffective. Concentrated, nobody can work longer than 5 hours a day. Furthermore, it can be assumed that the error rate will be around 2-5% due to decreasing concentration.
This means that it will take about 3.5 days, + 2-3 days, because the troubleshooting will be very nickel-prone. In addition, you can safely add at least 0.5 days until you have trained someone enough to continue working independently.
To develop a program would take about 0.5 days, the execution would take about 700 sec = 12 min. The error rate would certainly be well below 0.1%.
So, it is now to Daniel to decide which way he wants to go
Volker Hüfner said:Im my opinion, a human approach in such a solution is very ineffective
Totally agree with you 100% , but 20 hours pay is a good estimate on an experienced user over a few days and can be used as the basis for building a business case to pay a developer to do it in vba for you instead of manual method and will probably work out cheaper than manual method and lower error rate too and as I said is it worth the effort for manual method and cost?... I think not but his masters may not permit paying for developer...
Hi Daniel,A redesign of the linestyle editor is considered by Bentley for the future. Near future? Nobody knows. However in the Idea section there are at least five ideas considering the linestyle editor that you can stil vote on. Here's two of them.https://communities.bentley.com/products/microstation/i/drafting_and_detailing/improved_linestyle_editor
andhttps://communities.bentley.com/products/microstation/i/user_interface/modernised-linestyle-multiline-editor
Or type down your specific needs and post a new idea her:https://communities.bentley.com/products/microstation/i/
Good luck
Ivo Blaauw= = = = = = = = = = = = =Look what the CAD dragged in...
