We've been forced to upgrade to Microstation CE and ribbon is taking too long to navigate. I've found most of what I need in tool boxes but all the Classic ones are gone.
Do I need to make custom toolboxes to get them back? or am simply I missing something?
Thank you.
I assume you're talking about the V8i Tasks Menus...https://communities.bentley.com/products/microstation/w/microstation__wiki/43148/enable-v8i-task-theme-in-microstation-connect-edition
Otherwise the Main, Primary, etc. toolboxes used prior to V8i are still available under > File > Settings > User > Toolboxes....
Not all of them Andrew, and that goes for some of the verticals as well. Great pity toolboxes like Structural Linear are no longer available.
Not sure what you're meaning by a "Structural Linear" toolbox. This does not appear to be a default toolbox available in XM or V8i. Is this something provided by other software or tools?
**Update**
A Google search seems to indicate the "Structural Linear" toolbox is a part of the AECOsim BD V8i software. You might like to post any issue you have to the forum that supports this software.
https://communities.bentley.com/products/building/building_analysis___design/
In V8i we had Main and Main Classic (from 2004 maybe?) Main classic generally included the most basic drawing tools you always needed.
I think you need to create your custom tool box to see in CE. You could refer to https://communities.bentley.com/products/microstation/f/microstation-forum/191213/v8i-tasks-in-microstation-connect about how to get the Main Classic tool box.
Hyung
