I want to delete sets tags from all files except one ast tag which is seed2blk. Can someone help me with this .
I have 100s of files and i i want only one tag SEEDS2TBLK and remove all other tags from all files in a one process don't want to go manually for every file
Is it possible to do with keyin or project manager ?
Please check the screenshot on tags
Please can anyone
It is expected good practice to always start all posts I'm using MicroStation Version XXX, it appears from this post and others you often forget this but you seem to be using V8i... The answers we give in these forums very much depend on the version your using, in future remember to state the version at the front of your posts.
If your not a confident programer, then this type of requirement is always best done by recording a macro (VBA) because it creates the vba programming for you.. first you look at how doing all the steps by hand work, then repeat those steps with another drawing but have the vba recorder running then test again with another file and run the recorded macro you created, if it worked then you can use the macro in the batch processor utility in microstation and you add all the files you want to process, I would recommend keeping your list of files to process in medium size groups say 100 at a time .. if you use too big a grouping it may crash microstation
Lorys
If all files use same tagsets then there is one option with old v8 MSMACRO to open dialog and delete tags using dialog buttons.
See this example it does the opposite but could help.
Sub main Dim startPoint As MbePoint Dim point As MbePoint, point2 As MbePoint ' Start a command MbeSendCommand "DIALOG MDL " MbeSendCommand "MDL SILENTLOAD TAGS DEFINE;DMSG FOCUSDIALOG 1 TAGS;VBA EXECUTE Sendkeys ""%FIT""" mbemacro.suspend MbeState.modalDialogByUser=1 ' Opened modal dialog "Open Tag Library" ' Opened modal dialog "Import Sets" ' MbeSendCommand "MBE1 CLOSEMODAL OK" MbeSendCommand "MDL COMMAND MGDSHOOK,fileList_setDirectoryCmd C:\V8i_Workspaces\WorkSpace\Projects\ATIS\data\" MbeSendCommand "MDL COMMAND MGDSHOOK,fileList_setFileNameCmd ATIS_Tagset.tlb" ' Closed modal dialog "Open Tag Library" MbeSendCommand "MBE1 CLOSEMODAL OK" End Sub
Another example how to move in dialog box using DMSG keyins.
Sub main Mbesendcommand "set sharecell on" Mbesendcommand "DMSG FOCUSDIALOG CELLMAINTENANCE" Mbesendcommand "DMSG CURSOR RIGHT" Mbesendcommand "DMSG CURSOR RIGHT" Mbesendcommand "DMSG CURSOR RIGHT" Mbesendcommand "DMSG ACTION OKAY" Mbesendcommand "place cell" End Sub
Afterwards this macro can be used on batch process but you will need v8i version.
Better approach would be to use this VBA and add that seeds2tblk is not deleted - https://communities.bentley.com/products/programming/microstation_programming/f/microstation-programming---forum/83962/deleted-all-tag-definitions-or-tag-sets/235920#235920
Thanks fro answer Mr Oto i am a beginner to microstataion i will try on this
