[V8i or CE] Creating simple terrain from survey levels
Not sure if there is a simple answer to this, I've got a topographical survey (see below) with various spot levels and I would like to make a surface where the path/kerb lines are correctly interpolated between spot levels whilst still being correct in plan. I can obviously extract the edges and make into a complex chain/shape but unsure if this can draped to correct levels at each point. Is there a simple solution to this? I'm not after a triangulated mesh, just something clean which I can then generate a 2D elevation using export visible edges.
