I am trying to change the Linestyle Corner Mode in many elements to "Run through Corners" in DWG files and am finding they all back to the Default "from Linestyle" setting on Save every time. This happens whether I do it via VBA or manually in the properties dialog.
Does anyone know a way around this? Is there a setting somewhere making this happen or a Defect?
Mark
Service Request 7001030567:
Would you be able to provide further details to help explain what it is that you are trying to achieve with this operation. It would be helpful if you could provide details of the workflow for what you are trying to perform along with screen captures, example files, etc. for us to try to understand your problem. Any other details you could supply would be most helpful.
ok sent
Video below for the benefit of anyone else experiencing the same issue:
OpenRoads Designer 2022 R3 (10.12) | Microstation 2023.1 | ProjectWise CE 3.4
