Hi
Can someone check the DWG file with these display issue in Bentley View CE13
ACAD-200131_TExtstyle_issue_BentleyView_issue.dwg
I think this is an old issue
I believe Defect # 1054558 may be related to the display issue you are highlighting here. You might like to raise a new Service Request so this can be linked for updates.
Answer Verified By: Frank Klein
Thank's it seems it is not fixed yet (Bentley View CE14 )
Frank
