In Bentley Connect, is there a way to export a custom workflow and ribbon in order to import to other users and configurations?
f.mandoki said:We exported our ribbon customizations and imported them on another machine with the mentioned key-ins
Why you did not explain this in the first question?
f.mandoki said:What information are you missing here?
Missing information is for example:
The displayed customization is the last step in complex chain, so every step should be checked.
Jan
Which version were this customisations created in.
Ribbon customisations are stored in a DGNLIB file and the configuration variable MS_GUIDGNLIBLIST should point to a folder where this DGNLIB file is located.
In a standard installation it usually resides in the WorkSpace folder.
C:\ProgramData\Bentley\MicroStation CONNECT Edition\Configuration\WorkSpaces\YourWorkSpace\Standards\Dgnlib\
Try copying the DGNLIB file to the above folder in U17 and the customisations will load.
Refer Customizing the Ribbon
On the original machine you will have to find where the workflow is saved. You can hover over the workflow in the customize ribbon dialog and it should tell you which dgnlib its saved to.
Once found copy the dgnlib to the new machine to a location where it will be read by the ms_guidgnliblist variable
