when i open a microsatation file from (example D01 folder ) and when i open second file in another tab from (D02 folder) and when i close file opened from D01 it taking me D02 folder. why cannot it maintain different location for different tab
please can someone help me with this settings any answer to my question would be appreciated thanks
what is setting i want to maintain same folder location for a file whenever i close file by ctrl+w
Your questions are often unclear. Keep in mind that we can't see what you can see, unless you provide a screenshot.
King Khan said:when i open second file in another tab
What do you mean by 'another tab'? Is that something in Windows or something in MicroStation?
King Khan said:when i close file opened from D01 it taking me D02 folder
What is taking you...
King Khan said:what is setting i want to maintain same folder location for a file
MicroStation file and folder locations are determined by your configuration. Your configuration defines configuration variables that MicroStation uses to find files. For example, the folders specified in variable MS_DEF are used to find DGN files.
MS_DEF
In microsation example 1. if i open a dgn file from folder d01 and 2. Another file from d02 03. when i close d01 dgn file with ctrl+w . its taking me to folder d02 when it has to take me to d01
When opening a file Microstation always takes you to the location you last opened a file from, no matter which program instance you close.
Microstation doesn't support tabbed working, though. So what you probably do is open multiple instances of Microstation which, however, Bentley doesn't suggest doing due to possible user preference file corruption.
Exactly you got my point (Microstation always takes you to the location you last opened a file)
i am just getting irritating with this
is there anyway you said me to do ? (So what you probably do is open multiple instances of Microstation)
Thanks MR f.mandoki
I wouldn't know any workaround, it's just how Microstation works. All program instances share the same user preference files. So the path to the last opened file will be written to your user preference and you can't do anything but live with it.
