Associative option in Create Saved View
Trying to CLEARLY understand the Associative checkbox option in the Create Saved View dialog (MicroStation CE Update 10).
When my Saved View uses the existing clip volume, it doesn't seem to matter whether the box is checked or unchecked.  I can't find any differences in properties or function other than a checkmark in the IS ASSOCIATIVE column of the Saved Views dialog.
In some other reading, I get the impression that this checkbox only pertains to a Named Fence.  Not clear if the Clip Volume had to be created with a Named Fence.
Any complete explanation, or direction to one, would be greatly appreciated.
Parents Reply
  • If I create a saved view say 5X7 via 2 points  then later I need it to be 6X9 .. not sure what the associative does..But I have to delete the saved view and make  a new one to make it cover more area..... not sure what the associative would do to make the saved view do... as its a live ref and  if you change whats defined in the save view it is reflected where you attach it...
    Lorys
    click link to PM me
