My dialogue box's in Microstation keep freezing.. like I try to open Workspace>Preferences>Mouse and wheel.. but I am unable to close it or make any changes as its frozen every single time I open it. Can you help me with this?
I have tried rebooting my laptop closing and opening Microstation again but nothing helps. Can anyone help me with this please....
Which Version are you using ? May be down to permissions see 1 https://communities.bentley.com/products/microstation/w/microstation__wiki/13452/troubleshooting-user-preferences-issues
Carl Myhill
Technical Support Engineer
Bentley Systems
I am using MicrostatioV8i
if not permission / saving related may be a Restore would help https://communities.bentley.com/products/microstation/w/microstation__wiki/8671/restore-microstation-to-factory-defaults
I am unable to make those changes as I do not have the admin rights to Microstation.
Point number one in the link Carl shared says trouble may occur when the user does not have admin rights to Microstation or the preferences file.
That sounds like you need to have a brief talk with IT to make sure you have enough permissions to fully run the software. If you don' have the correct permissions, you won't be able to make changes to your preferences (among other things). Your IT department will need to fix that for you. Nothing we can really do on this end until they make those changes.
MaryB
