How do i load Autocad's .ctb in Bentley View V8i (SELECT series 3)
Dear Colleagues,
I tried to follow as per this link https://communities.bentley.com/products/microstation/microstation_printing/w/wiki/13571/how-to-manually-attach-an-autocad-ctb-or-stb-plot-style-file-in-microstation but unable to adopt the same for Bentley View.
Please advise.
  • Don't use the windows printer  choose the Bentley   printer driver pdf.pltcfg  then  you should l have access to attach pentable and  then you can choose the acad ctb to make your pdfs... Depending on how IT have set you up you may not be able to edit a copy of the pdf.pltcfg to suit your  requirements...
    If you trying to print  DWG files to pdf through microstation then you should not have any surprises using the acad.ctb ..
    Its been a while sine I used Bentley view but it should work this way
    Lorys
    click link to PM me
