I'm currently using the latest Microstation Connect Edition for a few projects I'm working on. I am running Microstation via a remote session using Windows Remote Desktop. Whilst the session is running Microstation performs as normal. I however have frequent issues with connectivity to the remote session meaning I have to restart the remote session regularly. Every-time I reboot a session it causes Microstation to glitch whereby I can use Microstation for a few seconds before the whole program freezes and becomes unresponsive the only to option is to force crash Microstation. All other programs running in the background run are as normal
Is this is a common issue whilst using Microstation via a remote desktop, and can anyone offer any advice. Happy to provide more details if need be.
Mark
Kindly log a Service Request and provide the crash logs (exception.log, Minidump.dmp). We will require the Event Viewer logs.
How to quickly find and collect Exception logs and Minidump files
Event Logs
Please check the event logs for any errors. Kindly save the Application and System logs, email us.
To get the system and application logs:
For a test, disable Direct X 11 and reproduce the problem. Create configuration variable QV_DISABLE_D3D11 and set the value to 1 or create a system environment variable.
QV_DISABLE_D3D11 = 1
