When I Rotate view element – Compass does not rotate to view, but Auxiliary instead.
I am not sure I am using the right terminology, so bear with me.
I often use the I Rotate view element.  But normally when I do that my accudraw compass rotates with my new view orientation.   For in the one drawing it stays oriented to the auxiliary view.   So every time I draw something, I need to rotate my compass with the ACCUDRAW ROTATE VIEW command.    I went under settings menu “accudraw” and in the coordinates tab, it’s set to rotation as “Auxiliary” instead of View.    If I select view instead, it does not remember that setting.  It goes back to auxiliary.   I did a search on the bentley site and they mention a corrupted user pref file etc ...   but I don't think it applies to me, since all my other drawings remember that setting except this one.
Is there a way to fix that?
thanks
